WSA S370 Hardware Capacity
Mafiaboy401
Hi everybody!
We are doing IP Performance Test in your WSA S370 and would like to know what is the maximum hardware capacity supported according the informations below :
We didn't find this information in cisco website.
- Total Transactions per Second:
- Bandwidth (Mbps):
- Total connections:
Anybody can help us?
Chris Illsley
Level 3
Level 3
Haven't you asked this before:
Correct Answer by Christian Rahl  on Aug 15, 2012 9:46 AM
Christian Rahl
Depends on what you are going to use on the device. What engines and services were you going to use?
Christian Rahl
Customer Support Engineer
Cisco IronPort - Web Security Appliances
Cisco Technical Assistance Center RTP
United States Ironport: 1-877-641-IRON (4766)
See the answer in context
Correct Answer by Christian Rahl  on Aug 16, 2012 9:02 AM
Christian Rahl
It can handle anywhere between 40 and 60 Mbps, for each WSA with a full suite of engines and features. The maximum is 100 Mbps.
Christian Rahl
Yes, I did.
But the informations is not clear, we are using the engines sophos, web reputation, FTP proxy, HTTPs Proxy, anti walware.
We did a Performance Test and the device not passed from 50.000 connections and 700 transactions per seconds.
I dont see any document on cisco website, only refering 10.000 users.
Do you have this information?
Thanks.
