Disable thin client / Join by browser?
IchiroA
Visitor
Any way I can force attendees to install WebEx instead of the option of using the Browser?
The thin client is so buggy and depends so much on their browser settings.
Andres Salgado
Hi IchiroA,
If you open a TAC case, I understand a ticket with the provisioning team can be submitted to disable the join by browser option.
Andres
Response Signature
