Problem Youtube Streaming Live
MarcoMura98452
I'm having a problem starting Youtube Streaming Live.
When I type data on the popup the button "Start Live" is always disabled..
How can I fix the problem?
Marco
11 Replies 11
Solenn.BOUTTIER
Thanks ! I gave the info to my IS, hope it will works too ...
andrea6
I edit my last message.. I wrote with the phone and I made an error.
The update 40.8.8.6 works well !
andrea6
Yes it was solved a few days ago with the Windows App Desktop v. 40.8.8.6
Support says that it was a bug for italian and franch users
For me, now it works (in italy) !
Andrea, where did you find this version?
in english:
https://www.webex.com/downloads.html (windows download)
and after install, open the app, and check for update (now we are on v. 40.9.3.20)
in italiano:
dopo aver installato il software, per certezza, controlla se sono disponibili aggiornamenti (l'ultima versione è v. 40.9.3.20)
Unfortunately the problem persists, the downloaded app is correct 40.9.3.20 but starting a meeting on Cisco Webex Meetings results the Version 40.8.7.13
1) download the app from https://www.webex.com/downloads.html and install it;
2) launch the desktop app just installed;
3) click on the icon  "app setting" and choose "check for update";
3) always in "app setting" verify Your desktop app version;
Now, I have the v. 40.9.3.20 and it works well for YouTube streaming. Testing days ago and just now!
Niente da fare, fatte tutte le prove possibili anche su altri pc
sorry but I don't understand Your specific problem.
When You try to start streaming with YouTube live servicies, You have the botton "start streaming" disabled, right?
If the problem is this, I solved it with the update of the windows app;
.. but I don't know Your OS (Windows 10? windows 7?)  or if Your are behind a firewall .. or antivirus block Your app;
Solenn.BOUTTIER
Same problem ! It's solved for you ? Did they respond to your tickets' ?
There is something I can do or this is a Cisco problem ?
Thnaks for your help
Solenn
andrea6
same problem ... ticket open 1 week ago .. the problem isn't solved yet
