WebEx License APIs
I am working on getting API's for gathering license information for WebEx from control hub. I want to use this information in splunk to create dashboard. Adding to it i am looking to get user contact numbers,
user info: Contact number - Primary, Secondary, Mobile etc.,. Can someone assist me on this if some one has done this earlier.
Thanks in advance.
Ashish Patel
Try this
Create an account which is also hopefully where you are admin of your Webex control hub
Go to developer.webex.com
Under REST apis check out the Licenses and People APIs that will give you what you are asking for.
If your admin rights are correct for your account you may be able to execute the calls in the browser next to the API just to see some REST API calls and results
If you need support you can open a case with developer support.
Ashish
Response Signature
