How to disable White Board function on a Webex Board Pro
gfolens
Level 4
Level 4
On a Webex Board Pro you can remove the button "White Board" from the user interface. But when you go into screen sharing mode you still can activate the White Board function with option to save the White Board screen to a Webex space or to Onedrive location. Is there a way to disable this function?
0 Replies 0
