I would like to ask whether the microphone input interface of the CS -
caertion
I have deployed a CS-KIT-K9 in my conference room. There is also a mixer in the conference room that is connected to multiple microphones. I want to send the sound from the AUX 6.35TRS output port of the mixer to the CS-KIT-K9. The AUX output of the mixer is a balanced mono XLR interface, while the two microphone interfaces on the CS-KIT-K9 host are both 4-pin interfaces. I need to know the signal wire sequence of the 4-pin interface in order to make the cable, or could you please suggest how I should make the connection?
If you have a look at SX20 pinout description - Cisco Community, you'll find the pinout.  It's the same on the Room Kit as it was on the older SX device.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
