Problem Updating Codec Pro from RoomOS ce11.5.3.3 via WebUI
danie g
I'm having trouble updating a Codec Pro (S53300) running original RoomOS ce11.5.3.3 to a newer version. No matter which version I try via the WebUI, the file uploads successfully, but the update process never actually starts. I've tested this with two different Codec Pros and multiple software versions, but the issue persists.
Has anyone encountered this problem before? Any advice would be greatly appreciated! many thanks!
justin-v
Hi Danie,
Did you figure out what was wrong with it?
Justin
