Webex Devices Management
Faisal Saoud
We have multiple Webex devices registered to the cloud. Is there a way to combine them into a single link that can be added to the company portal, allowing users to see when a room is available and schedule their meetings accordingly?
Stefan Mihajlov
Level 3
Level 3
@Faisal Saoud
for cloud-registered Webex devices there isn’t a way to generate a single “combined” booking link directly from Control Hub. The scheduling and room availability piece comes through Calendaring integration (Hybrid Calendar or M365/Google integration) - i personal use m365. Once that’s in place, each device/room has its own resource calendar in Outlook or Google Workspace — users check availability and book it just like a meeting room.
If your goal is a single portal link where employees can browse all rooms, the typical approach is to surface those room calendars in your company’s intranet or booking system. Many customers use Outlook/Exchange “room list” or Google “resource calendars” for this, then embed or link that view. Webex itself doesn’t consolidate multiple devices into one URL, but it does expose free/busy status once the calendar integration is enabled.
So the practical solution is: integrate Webex devices with your calendar service, then publish or link the room calendars in your company portal for employees to see and schedule.
Best regards,
Stefan Mihajlov
Mark this post as Helpful if it helped you, and Accept as Solution if it resolved your question.
