Create a webex bot using cisco .gen account (Generic account)
svaramba
How to create a webex bot (and get Token) using Cisco  .gen account (Generic account). I am aboe to generate with my Cisco ID, However I need the bot to be created using Cisco .gen account.
What is the process for the same?
Janos Benyovszki
@svaramba not sure about that, I don';t usually work with .gen accounts, but as long as you can log in with an account on the Dev Portal https://developer.webex.com/ , you should be able to create a bot the same way that we have it documented here https://developer.webex.com/create/docs/bots .
