Get location result wrong?
michael.aebi
Visitor
Locations with Locations - List Locations | Webex for Developers
I’m having an issue with the GET /v1/locations endpoint in the Webex API. When I call this endpoint with the id parameter to filter the results by a specific location ID, I’m still receiving all locations in the response, rather than just the location with the specified ID. Am I misunderstanding how this endpoint works, or is there something else going on?
I guess it is a bug.
Janos Benyovszki
@michael.aebi  I was able to reproduce this just now. I will report it to engineering, however in case you want to get updates about the status of the engineering bug, I would still recommend opening a ticket with us.
Enjoy your vacation.
michael.aebi
Visitor
Does it work for you?
Janos Benyovszki
@michael.aebi best would be to send the full request and response, including the tracking ID from the response header to [email protected] , so we can look into it. Thanks
Did you try it? If not it seems to me that cisco does not realy care about it. Im on vacation and cant run this simple request for you. I just want that you tell me if ut works well or not. Thanks for a answere
