Hide/Mute spaces using API
vsheel
Hi everyone,
Recently with some automation tasks I am getting added to lots of spaces by bots. I looked for apis to hide or mute a space but couldn't find them in the api docs. I would like to know if anyone of the below options are supported and how to do it? My objective is to not them manually via webex app one by one, but instead have a script to do it for me.
1. Hide spaces using API
2. Mute notifications of a space using API
3. Webhook for notifying when a space is created by a bot which I am a part of
4. Create sections using API and move spaces under them
Janos Benyovszki
@vsheel here are the answers to your questions:
For this you can use the https://developer.webex.com/docs/api/v1/memberships/update-a-membership API once you located your membershipID for that space using https://developer.webex.com/docs/api/v1/memberships/list-memberships .
This would be a new requirement that you can suggest here https://ciscocollabcustomer.ideas.aha.io/
See the memberships:created webhook here https://developer.webex.com/docs/api/guides/webhooks#filtering-webhooks . You can create one using https://developer.webex.com/docs/api/v1/webhooks/create-a-webhook .
Janos Benyovszki
