How to attach a file from Groovy
slapierr
I want to attach a file to a message, sent from a Jenkins pipeline written in groovy, using simple notifications, not cards
dtibbe
The Cisco Spark Notifier Plugin for Jenkins seems not to support file attachements, so you'd have to build your own tool for that or enhance the plugin...
When doing it on your own: There is an example on how to send files using a curl command at https://developer.webex.com/docs/basics#message-attachments. Guess you may call it similar from within your pipeline. A bot access token would be sufficiant if the bot it in your space..
dtibbe
slapierr
I am currently using sparkSend to send simple notifications to a space, example:
sparkSend  credentialsId: 'jenkins-rialto-bot', message: "some message", messageType: 'html', spaceList: [[spaceId: someId, spaceName: someName]]
I want to add a file attachment in the simplest possible way
