How to get more then 500 location in api
mahendra09
if create more then 500 location in but when i use https://developer.webex.com/docs/api/v1/locations/list-locations this but only 500 location.
what solution for get more then 500 location?
It would help if you can provide details on exactly what's happening, are you getting an error or something?
For me, I was able to pull the initial 500 locations and then in the Response Headers I can see that there is a header called "Link", which contains a url link to the next page. see here;
Just need to remove all the un-needed characters (like the arrows <> and the ; rel="next" at the end) and it works. See here:
I used Postman for this test as I don't have a code sample on hand to do this. But API works for me as you can see.
6 Replies 6
Raffaele Lagana
Have you tried Paginating results?
yes but it's not working so please give me one example
Thank you
Why is it not working? Is the link header missing? Is the link not working? What error message do you get?
No errors occur; only 500 locations can be retrieved, not more.
