How to increase the width of adaptive card in webex?
Muhammad-Ali6
I have a webex bot which fetches details from Jira and sends them in table format, but the message/card width is such that it is not able show all the columns. I noticed that this is not the issue when I open the message in my mobile app and change orientation from portrait to landscape. Is there a way to handle this, like increase card width or maybe some orientation settings?
sandiban
Hi @Muhammad-Ali6,
Max width supported for Webex Adaptive Card is 432px and you can't increase it further.
Same has been documented in Webex Developer Portal FAQs section as well (under 'Card' section) - https://developer.webex.com/docs/frequently-asked-questions#cards
There was a feature request raised for it by last year middle - https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-13605 to be able to expand it more, but that was cancelled by our Product Management team.
So, it can't be expanded more.
Regards!
Sandip
Please Note: If you think the solution provided above was helpful and satisfactory, please accept it as a Solution! However if you want to discuss it further and get yourself unblocked, please don't hesitate to reply back on this thread and we'll try to answer those queries by the soonest. In that case, once all of your queries are cleared - finally you can mark it as "Accepted as Solution"
