How to use webex.authorization.requestAccessTokenFromJwt({jwt})
Raffaele Lagana
Hi, I'm new to Webex JS SDK and Javascript, and I want to log the access token to console after getting it by calling webex.authorization.requestAccessTokenFromJwt({jwt}). How does this work?
Raffaele Lagana
That function is simply making a POST request to
https://webexapis.com/v1/jwt/login with whatever the jwt value is. It would be in an Authorization header as a bearer token.
We have a great sample that uses exactly this method to authenticate the JWT, you can check it out here: https://webexsamples.github.io/browser-sdk-samples/browser-auth-jwt/ . Code for that sample is found here: https://github.com/WebexSamples/browser-sdk-samples/tree/main/browser-auth-jwt (the app.js file contains this function)
Raffaele Lagana
