Setting Space Photo
Jeremy Combs
Level 3
Level 3
Which API Endpoint can I use to set the Photo (aka Avatar) of a Webex Space? I thought it would be under the Rooms API Endpoint but, it is not.
Rudrakshi
@Jeremy Combs That's correct! It is not possible to add/update the space avatar via API. If you'd like, you can submit a feature request on the portal: https://ciscocollabcustomer.ideas.aha.io/
Best regards,
Rudrakshi Srivastava
