Unable to access Webex Assistant Skills documentation
YSHui
Hi, I can't access Webex Assistant Skills documentation via the link https://developer.webex.com/docs/api/guides/webex-assistant-skills-guide. Has the feature been removed?
Best Regards,
YS
sandiban
Hi @YSHui,
As we discussed over #webex4devs space in Webex, this page is currently not available anymore over the Developer portal.
I discussed about it with the Documentation team internally and the corresponding Product manager, and shared the outcome in the space discussion.
Hope that helps! Thank you.
Regards!
Sandip
sandiban
Hi @YSHui,
Regards!
Sandip
