Webex API - Configure Emergency callback number for a person
Lirit Sagie
I would like to configure the Emergency callback number of a user using a Webex API call.
I found here https://developer.webex.com/docs/api/v1/user-call-settings  most of the services that I need in order to configure the person's features via API but I failed to find the Emergency Callback number,
Is there an API for that? Is it a documentation issue?
Lirit
Janos Benyovszki
@Lirit Sagie I am not aware of this setting for Users, only for locations https://developer.webex.com/docs/api/v1/location-call-settings/update-a-location-emergency-callback-number . You can raise a new feature suggestion for it here https://ciscocollabcustomer.ideas.aha.io/ideas .
@Janos Benyovszki Thank you for your response.  That's the setting in the user level:
Unfortunately, there is no API at this time for user level emergency callback number. It is something that's already coming but not sure exactly when it will be available at this time. Once available it will be part of the User Call Settings APIs.
