Webex Calling API for "call decline"
simonunivonix
I am looking for the Webex Calling API that can be used to configure the "call decline" setting.  In control hub this setting can be found in Device Details > Customized Behaviors.
simonunivonix
To the best of my understanding the links you sent refer to rules that can be set to automatically reject certain calls based on time of day and incoming number.  I am looking to set what happens when an incoming call is manually rejected by the user on a line that is shared between multiple devices.
Yes @simonunivonix, your understanding is correct here!
I probably missed that while checking the APIs for your use-case, my bad!
But it's also true that there is no Calling API at this moment available to handle the manually rejected calls unfortuantely.
You can raise a feature request may be for this item to handle certain scenarios, and you can use Webex's AHA public Feature request platform to get that done here - https://ciscocollabcustomer.ideas.aha.io/
Our Product Management team directly review these feature requests and they create roadmap accordingly.
Please let us know for any further assistance or, queries.
Regards!
Sandip
sandiban
Hi @simonunivonix,
Thanks for your patience so far!
So, you can actually follow this screenshot attached as I've highlighted here.
Basically from Webex Developer Portal - Documentation tab, you select the Webex Calling option and in the lest hand panel Search box of Webex Calling details page, you search the keyword - "reject".
You will get the API details for setting up Call rejection for a Workspace.
Let me share the direct API link here as well for easy access -
Create (/POST) selective reject criteria for a Workspace - https://developer.webex.com/calling/docs/api/v1/workspace-call-settings-2-2/create-selective-reject-criteria-for-a-workspace
For Users, you can't set up a Call rejection criteria through API though as of now, however you can list our the Call reject criteria for a User or, modify it as well through Webex Calling REST API.
Again let me share the direct API links for easy access regarding the User's Call reject criteria -
/GET selective reject criteria for a User - https://developer.webex.com/calling/docs/api/v1/user-call-settings-2-2/get-the-user-s-selective-call-rejection-criteria-listing
/PUT selective reject criteria for a User - https://developer.webex.com/calling/docs/api/v1/user-call-settings-2-2/update-user-s-selective-call-rejection-criteria-list
Hope this helps!
In case of any further queries, please let us know.
Regards!
Sandip
