Webex Create a Guest API
otter-phil
Visitor
I have some questions about the guest tokens you can create using this API: https://developer.webex.com/admin/docs/api/v1/guest-management/create-a-guest
Is there a rate limit on the number of tokens you can create using one access token? Also if the guest token is then used to call other APIs, is the rate limit enforced per guest token or per the original access token?
Also, for the guest tokens, is there any notable restrictions on what meetings it can join? For example, if someone creates a guest token under Org A, would the guests only be able to join meetings from people in Org A, or would it be able to join meetings from other Organizations as well?
Janos Benyovszki
Webex does rate-limit POST /v1/guests/token, but we do not have public fixed numeric limit; if throttled, the API returns 429 with a Retry-After header that the app should honor. The create-token call is authorized by the Service App token with guest-issuer:write, while later API calls use the issued guest accessToken, but there is no strict “per guest token” quota guarantee, so handle 429 for both flows. Also, guest tokens are limited-purpose temporary identities: they can interact with regular Webex users, and join Meetings from other orgs.
Janos Benyovszki
Thank you for the details!
