Webex Status API- Scheduled Maintenances Location?
aavgerin
Hello!
I have been trying to use the Webex Status API to build a customer feature.
The issue is, that all the response parts containing Scheduled Maintenances, include most of the details that can be viewed in the website as well, apart from the location. Meaning, which of the Data Centers will be impacted.
This is crucial information for the customer, to know if an upcoming maintenance will have impact on them or not. Is it possible to get this information from somewhere, using API?
Can it be included in the API response?
Thanks a lot!
2 Accepted Solutions
Janos Benyovszki
@aavgerin indeed, unfortunately right now the Status API does not return location. You can suggest this as an improvement here https://ciscocollabcustomer.ideas.aha.io/ .
aavgerin
Hello, thanks for your answer. Indeed I ended up raising a feature request in the AHA portal.
The link is here: Webex Status API - Location of | Collaboration Sales Feedback (aha.io)
aavgerin
Janos Benyovszki
