WebEx Training Center - Waitlist API Enabled
KerryHowe2929
Community Member
I am looking to Enable waitlist’ piece to WebEx as a part of the XML body it sends to the API. I was not successful finding it in the WebEx’s API documentation. How would the API  expect to receive that piece of information from the LMS?
Mike Palkovich
@KerryHowe2929 If you are referring to the Training Registration waitlist feature(shown in screenshot below) it is not supported by the API unfortunately.  Please consider submitting a feature request for this at https://ciscocollabcustomer.ideas.aha.io/.
Hi!
Yes, you are correct. It use to work. Has something changed?
Janos Benyovszki
@KerryHowe2929 not sure which Waitlist you mean here to be honest. I searched the Training Center XML API reference docs, but could not find anything related https://developer.cisco.com/docs/webex-xml-api-reference-guide/#!training-session-service-overview . Would you mind elaborating, which API request you exactly mean?
Hi, What I am looking at the option in the above screenshot above Mike posted. It use to work but, something seems to change.
