About RoomKit Voice Limits
Translator
Community Manager
Community Manager
I'm trying to limit the volume of RoomKitmini using the Cisco official sample split.
https://github.com/CiscoDevNet/roomdevices-macros-samples/tree/master/Audio Safe Guard
If you hit the volume button of the Room Navigator at high speed, the maximum volume will be limited, but the maximum volume will be exceeded on the RoomKit. (If you hit the volume buttons at a high speed, the maximum volume is 70, which means 70, but the volume on the RoomKit is 70 or higher, and if you lower the volume until the volume is 70 or lower, an error is displayed.)
Is it a problem?
0 Replies 0
