Add users automatically to a Webex space
ribeluc
Hello, it's possible to automatically add users to a Webex space?
AD group onprem ?
Webex Group dynamic ?
The goal is to create a space with around 1500 employees but new employees should be automatically added to this group. If possible.
Thank you for your answers.
dtibbe
If your employees are in a deidcated O365 group, you may have a look at https://help.webex.com/fyyrxq/
If you do not want to add them manually, you may also create a tool using the API, utilizing the memberships endpoint: https://developer.webex.com/docs/api/v1/memberships
And for sure you may create a public space (https://help.webex.com/r78evy/) or use https://eurl.io/ and inform new users in a brief welcome mail that they should join that space manually.
