Elgato Stream Deck Hotkeys are not working in Webex
Orhan42
i have an Elgato Stream Deck MK.2 and wanted use Hotkeys to turn on Camera or Mikrofone.
On MacOS it works like charm, but on Windows 10 and 11 it did'nt work in Webex.
Webex did not accept any Hotkey Command.
In other Apps it worked normal.
Has someone a suggestion?
Thank You.
Best regards,
Orhan
marcus@ibm
I have the same issue, and just posted a 'feature request' to integrate Elgato Stream Deck with an app.
How do I 'me-too' this post?
Anybody came up with a solution? A plugin? Been searching for days in and out.
If no solution yet, please follow and support this feature request here. Thank you!
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-7954
robertr
I have a problem with Webex and Stream Deck Mini, just wanted to toggle Fullscreen, Bottom Controls, and Mute myself On/Off. Setup hotkey with no luck.
