Feedback 2 room systems, Dual 70 and Pro kit connected to each other.
mschmatz
First we connect the two spaces through a personal room or direct calling. When the two spaces are connected if you are in the Dual 70 room, when you speak you get a quick burst of feedback of your audio being fed back to your room the other room. If you turn the volume all of the way down in the Pro Kit room the feedback will go away but then you can not hear conversation either. This leads me to believe the audio is getting fed back to the dual 70 room for an instant while the system makes a correction. How can this be mitigated? Noise cancelling off or on has no effect.
Audio in the reverse direction does not provide any feedback in the Pro Kit room. The Pro Kit room also has 3rd party SHURE ceiling mics and we use that set up in other spaces without issue.
Thank you for your assistance.
0 Replies 0
