How do I leave ALL my webex spaces simultaneously?
john.sullivan3
How do I leave ALL my webex spaces simultaneously? I have changed roles and I am in 100s of webex spaces and would like to remove myself from every space I am in.
Hi @john.sullivan3
You can try the Power Pack for Webex Teams: https://power-pack.io/
Once you are logged in, you can select multiple spaces that you are a member of and leave them.
Sachin Vittal Amin
Hello John,
Currently, there is no option available that would allow you to exit from all the spaces at once. There is an alternative way or workaround to achieve the same and that would be to leave the Teams that you are a part of. When you leave the Team you exist all the Spaces that are associated with that Team.
Steps to leave the Team:
1. Go to the Teams icon and click the team you want to leave.
2. Click Leave Team.
You can find steps on doing the same on desktop, iPhone, iPad, Android, and web in the article - https://help.webex.com/en-US/article/nay3ldv/Webex-App-%7C-Leave-a-Team#task_6D7FEB8CD741C5D29114D97C49AD02BA
Note: After you leave, you won't have access to any of the discussions, and you won't get any notifications of new messages in the team either. If you need to join the team again after you leave, you'll need to be added by a team moderator.
Regards!
dtibbe
I think you'd have to create a script for it, there is no one-click-button solution in the app itself..
Get a list of all memberships and then delete them: https://developer.webex.com/docs/api/v1/memberships
