How to copy/paste text with hyperlinks into webex?
spuddupa
How does one copy/paste text with hyperlinks into webex chat.
I am only able to paste it as plain text.
If i copy some text with hyperlinks (bug-id like below) from browser and paste it into webex chat, it pastes it as plain text.
Example:
CSCvx89615 [SAP] Shut/no shut of AP during dot1x authentication results in continous reload
If i paste the above line in webex-chat, it pastes it like this loosing the hyperlink.
is there some setting that needs to be enabled to be able to paste hyperlinks.
spuddupa
Thank you for the response.
I think i figured out what the issue was in my case.
I had markdown-enabled by default.
I disabled markdown and now i am able to copy/paste text with embedded hyperlinks into webex-chat.
Thank you.
Could you please advise where this setting is?
I have the same issue but can't find the setting you are mentioning.
thank you,
M
@Martyna.Talifre
Do you mean the Markdown setting?
Press Cmd+Op+M to toggle on/Off (guessing that's Ctrl+Alt+M in Windows) - or Edit > Turn on/off Markdown
RedNectar aka Chris Welsh.
Kathy N.
Instead of pasting the text, click on the link, copy the URL and paste the link.   It will create a hyperlink for you with the meta data from the website.
Response Signature
