Link Feature not working in Webex Messaging?
sgadolin
Hello:  I used to be able to highlight a word in Webex messaging and create a link for that word with the link icon.  For the last couple of weeks, the icon will let me click on it with the highlighted word, but the dialog box for the link doesn't come up.  Is this a known issue or a user error?  If a user error, can someone enlighten me as to how to do this now?
2 Accepted Solutions
Roray Stewart
Just tried that and I have the same experience, button does nothing. If you hover on the link icon you will see alternate text which tells you you can use Ctrl+K (Windows) which is working for me.
Thanks!   I opened a case and it is being worked by engineering - Appreciate the workaround!
Roray Stewart
