Meetings & Teams need lower background replacement requirements; Teams needs support for OBS Virtual Cam input
jdrch
I have a corporate Webex account I've tried both Webex Teams and Webex Meetings with on Windows 10. As I work from home, I'd very much like to replace my background and bought my own green screen for that purpose.
However, there are 2 problems with this:
1) Neither Teams nor Meetings support background replacement on my PC
Per both applications, my PC (Intel Core i7 3rd Generation, AMD Radeon HD 7870 GHz Edition) doesn't meet the system requirements. The problem is, Zoom does background replacement on the same machine just fine with no performance issues whatsoever. Ergo, Webex's limitation seems a bit ridiculous.
High requirements may seem trivial for enterprise fleets that get refreshed every 3 to 5 years, but they're not reasonable for those of us who work from home and rely on our personal machines that a closer to a decade old. And yes, Intel still provides microcode updates for my CPU, so it's still supported.
As a consequence of this, I've been forced to roll my own Webex background replacement using OBS Virtual Cam. In this setup, OBS does the background replacement, and then a plugin makes the video stream available via a virtual webcam device that any web conferencing solution can then use as a source.
This leads to my 2nd problem:
2) Webex Teams cannot pick up the OBS Virtual Cam stream
I find this odd, because Meetings picked it up just fine. It's also resulted in a professionally embarrassing situation in which, after migrating from Meetings to Teams, I hosted a meeting in the latter, only to find that I couldn't stream any webcam video. True, I probably should've tested it 1st, but I don't think it's out of line to expect Cisco's newer, heavily promoted Teams app to have the same basic functionality as the Meetings app.
Can these 2 issues be addressed?
Fritz_H
@jdrch
I have seen similar postings here recently regarding virtual webcams not working an MacOS-Systems.
As far as I have noticed, these issues are resolved by now - perhaps Cisco is still working on solutions for Windows?
(In my tests, failed completely to use OBS and VirtualCam 2.0.5 with any conferencing software...)
You may want to try other virtual webcam-Software.
(I have never used any of them)
ManyCam
ChromaCam
Snap-Camera
XSplit VCam
(I have no idea if "Logitech Capture" does support any Webcam.. but it does work with Webex and Webex-Meetings..)
Virtual Cams on MacOS will be supported with Release 41.2, but the administrator has to enable it.
It's listed in the feature overview for 41.2
https://help.webex.com/en-us/xcwws1/What-s-New-for-the-Latest-Channel-of-Webex-Meetings
@Sebastian LeuserThanks for the details. Per the very 1st line of my OP, I'm on Windows 10, so that development doesn't help me.
Thanks for the ManyCam link. I own ChromaCam and have tried XSplit Vcam. Ironically, neither support simple background removal via physical green screens and chroma key despite supporting the much more technically difficult AI background removal. Go figure.
Logitech Capture's chroma key video quality is awful, with pretty bad haloing and edge detection.
OBS' support is excellent and produces passable video quality. IMO, Zoom's built-in free chroma key support is the best I've ever encountered in terms of simplicity, usability, resource consumption, and output quality.
