Not able to integrate Cumulus Chat Bot to Webex
sandiban
Query from Ishan over #Webex4devs space
Ishan Kumarasinghe • I have a requirement to integrate socialminer webchat with a chat bot. In the dCloud i can see there is a chat bot called Cumulus. But i have no idea how the integration is done on there. even the chat requestes are not landing on the configured webchat csq. Could you please assist on my requirement.
sandiban
Hi @ishan,
I'm not exactly sure where you found this Cumulus Bot as you mentioned you got it from dCloud.
However, from the details you have shared, it looks like this is the Bot you're discussing about - https://www.airslate.com/bot/explore/cumulus-by-canto-bot
Please correct me if I'm wrong.
If this is the case, then unfortunately we can't do much on this since this Bot is not supported by Cisco. It is not available under https://apphub.webex.com/ and if you need any support on this Bot, you need to contact the general support for this BOT i.e., https://my.airslate.com/help-center
Please let us know here by replying on this thread in case if you need any further assistance on this.
Regards!
Sandip
Hi sandiban,
My actual requirement is to integrate socialminer web chat with dialogflow. in the following document in opage 23 I can see a diagram which indicates the integration with dialogflow.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/DEVNET-1196.pdf
I need to know the feasibility of this integtration and how the integration should be done.
