On-prem exchange integration with Webex
TimDooley0896
Hi All,
I'm looking to setup a WebEx trial for a customer and they have an on-prem exchange server.
They want to have OBTP (One button to push) for Zoom, MS Teams, and Exchange meetings.
My question is, do we Require an Expressway-C to be the calendar connector for the on-prem exchange, or are there other options?
Thank you all for you help in advance.
Tim
Eric Ingram
Level 4
Level 4
Exchange OBTP
First thing is the Webex site required to be control hub managed. And then how are your devices registered CUCM or Cloud? Because your exchange is on premise you need Expressway C. If CUCM as @lajos mentioned setting up TMS and TMSXE (windows servers, SQL) will accomplish OBTP for exchange meetings with Webex.
MS Teams
This will require hybrid calendar already set up. Then you need the MS CVI integration license (minimal order is 5) unless you can get a trial from you Cisco account team. This license will allow your MS administration with global admin rights to the tenant to set up the video integration to allow Cisco video units to dial into a MS Teams meeting (OBTP). If you have Cisco Webex Room Series you can use WebRTC to connect to MS Teams meeting with calendar integration
Zoom
First things first to connect with video unit you need the Zoom CRC host license. This means who ever is hosting the meeting requires this feature on there host account.  If you want to join another companies Zoom meeting they will need this CRC feature.  This license is per unit connected/per month cost. Same requirement applies for hybrid calendar set up.
You might want to consider Webex edge for devices while you are doing the trial so you can add webex assistant features where you can say to the codec "hey webex join Tim's Personal Room" along with other commands you can use.
lajos
In order to have OBTP you need a loal component that monitors email addresses of the video endpoint resources on the local Exchange server, then listens to the received invites and delivers scheduled notifications to the video endpoints.
Your options:
  • If your endpoints are managed by Cisco TMS (no cloud registered devices) then the TMSXE (an additional component to TMS) can provide this feature.
  • If your endpoints are managed by the Cloud (=you have cloud registered devices) then you will need an Expressway-C as Sebastian mentioned.
  • In certain situations Cisco has a hybrid solution described HERE where the device control can be maintained from both sides, by the Cloud and TMS, so you can opt which one to utilize
  • Later when you will have cloud Exhange (O365) then you will not need a local component to monitor the emails
If the endpoints are cloud registered you will require a expressway for the hybrid calendar service.
there are no other options to connect the booking information from an on-prem Exchange to cloud registered endpoints
