Virtual cam (OBS Streamlabs) not working after update webex
Ron136
After updating the newest version of the webex app (version 41.8.0.19868) I can not see or select my virtual cam (OBS Streamlabs). Re-installing doesn't fix the problem. Anybody an idea for a solution?
(The virtual cam does work in MS Teams, Zoom etc.)
Kind regards.
dtibbe
I just checked with my 41.9 beta, there the OBS is working fine..
Thnx for reply.
I am using version 41.8.0.19868
And because of my work can not use a beta version.
