Webex Flatpak for Linux (using DEB package)
It should be trivial to also provide us a Flatpak version of the Linux App hopefully on Flathub, so that distributions irrespective of types can run the same application in the same way (as far as I've seen, DEB packages can be easily repurposed to build Flatpak based applications, and have been by a lot of non-free apps like Skype, Teams, Zoom, Microsoft Edge, Steam etc.). If using Flathub, it would also automatically also make it available to app-stores on Linux.
Flatpak can directly download from Webex to the user system, with the Flathub only providing the build instructions, but which provides support for a lot more distributions than it presently has. I've seen Zoom and Microsoft Teams having Flatpak versions of their respective applications available in Flathub. It would be nice if Webex also supports Flatpak, as it would make it available for non-DEB/RPM applications also, without needing to put a lot of work.
If possible, someone from community also could work on this, also if we would be permitted to do this.
0 Replies 0
