There is a problem installing the webex rpm in openSuse linux Leap 15.4 version
zypper in /data/repositories/Downloads/Webex.rpm Problem: nothing provides 'libXcomposite' needed by the to be installed webex-42.6.0.22565-1.x86_64
Solution 1: do not install webex-42.6.0.22565-1.x86_64
Solution 2: break webex-42.6.0.22565-1.x86_64 by ignoring some of its dependencies Choose from above solutions by number or cancel [1/2/c/d/?] (c): 2
Resolving dependencies... Resolving package dependencies... The following 3 NEW packages are going to be installed:
libnotify-tools lshw webex
The libXcomposite1 is already installed in openSuse Leap 15.4 but Webex apparently does NOT pick it up. Can we fix this issue? I accidentally installed the openSuse factory repository and it ended up overlaying thousands of my linux files, causing a system crash and unbootable partition. I only just got things back up and running recently but have to do a fresh install of Leap 15.4 which is very time consuming.
