09-17-2020 09:19 AM
There is no way to adjust the volume on the iPad or iPhone Webex Meetings apps. I can get to the volume sliders (in-app and device audio), but they do nothing for adjusting the volume level. Kind of an important overlook on the app developers.
02-01-2022 01:54 AM
Now we are in 2022…, is any shortcut for iPad available to stop audio?
01-21-2021 03:04 AM
The only way to mute completely is form the dotted menu: Change Audio Connection (I have to translate this from Dutch, so it may show something else) and choose to have no connection. It's a work-around, The problem is indeed very annoying when I have a phone call...
12-15-2020 04:05 AM
I have a similar (or perhaps the same) problem. There hardware audio buttons on the iPad do influence the Webex volume, but only to a certain extent. You cannot turn the volume low or off, it hits a relatively loud minimum volume and is then unaffected by further changes. Very annoying when you need to temp mute output.
