Webex Meetings default template - can I not add a psw?
bolellicarolina
I am using the Webex Meetings default template to create a meeting. I do not want to have to add a psw by default in the template. It seems like a mandatory field with a red asterisk. Is it possible to change this?
I have had a problem before, as some participants were requested to add a psw to join the meeting, and others not. We didn't provide a psw, so there was a bit on initial chaos.
Thanks!
Carolina
Kathy N.
If you're using an organization account, you will need to check this with your Webex Control Hub administrator.  Requiring a password has several dependencies depending on the type of meeting and whether attendees are internal or external.  All of which are set by your administrator.
Response Signature
