Webex on Arch Linux - libxml2 related crash
moritz1108
Recently, libxml2 had a major update and led to errors. Since then, the Webex app can't connect to phone services anymore. I attached the log file (libxml2-error.txt).
This should be fixed by installing libxml2-legacy which provides the missing file. Instead this causes Webex to crash, crash_info, current_log and linux journal are also attached.
Does anyone have a suggestion how this can be fixed?
info-sic
using Kali Linux  (debian based) 6.12.38+kali-amd64 #1 SMP PREEMPT_DYNAMIC Kali 6.12.38-1kali1 (2025-08-12) x86_64 GNU/Linuxsame Problem. After a libxml2 update WebEx is unable to connect to the phoneservices and crashes. Does anybody know, where to find a .deb version of libxm2-legacy to try out?
david-schmidt
@moritz1108 you said this happened since some update to libxml2?
Can one not downgrade that, and only that, package?
I'll give it a try for sure
EDIT:
Nope..
error: failed to prepare transaction (could not satisfy dependencies)
:: installing libxml2 (2.12.7-1) breaks dependency 'libxml2.so=16-64' required by electron36
:: installing libxml2 (2.12.7-1) breaks dependency 'libxml2.so=16-64' required by libarchive
:: installing libxml2 (2.12.7-1) breaks dependency 'libxml2.so=16-64' required by sane
david-schmidt
Hi, having Arch on my home PC I have the exact same issue.
Also libxml2-legacy is required for Cisco Secure Client as well...
