01-04-2021 09:00 AM
Hi, hope anyone can help me out here. I have a brand new macbook air with OS Big Sur and just installed the Cisco Webex Meeting (version 40 12 5 14) and the virtual background option is not available. How can I make this work? Thanks
Solved! Go to Solution.
01-05-2021 04:39 AM
@MarianaAlmeida01624 , indeed strange that you don't get the option to enable virtual background.
I would recommend opening a TAC case for this (https://mycase.cloudapps.cisco.com/case)
01-05-2021 04:39 AM
01-04-2021 09:14 AM - edited 01-04-2021 09:44 AM
@MarianaAlmeida01624 , did you check if your MacBook Air meets the requirements described in the following article (check "Mac"-section)?
https://help.webex.com/en-us/80jduab/Use-a-Virtual-Background-in-the-Cisco-Webex-Meetings-Suite#id_138414
(Corrected link)
01-04-2021 09:24 AM
Thank you Goswin. Would you mind sharing the link for the article? Although since the computer is brand new I would be surprised if it does not meet the requirements. Thanks again
01-04-2021 09:43 AM
@MarianaAlmeida01624 , sorry I pasted the wrong link...
This is the link to the article: https://help.webex.com/en-us/80jduab/Use-a-Virtual-Background-in-the-Cisco-Webex-Meetings-Suite#id_138414
01-04-2021 09:54 AM
Thank you! I just read it and indeed my computer fulfill all the requirements (although not an intel processor, Ithe new mac has 8 cores) Any idea on what the problem can be?
