Whiteboard and Annotation Feature
KB10
If a participant does not have the Webex app downloaded to their desktop - are they unable to utilize the whiteboard or annotation feature?
EdgarArana91395
Hi, participants will only view the whiteboard and annotations. In order
to draw they will need the Webex App.
Edgar
EdgarArana91395
Edgar
RedNectar
Hi @KB10 ,
For some reason Cisco have lumped Webex Meetings and Teams in the same billboard.  So I have no idea if you are talking about Webex Teams or Webex Meetings.
BUT if you are talking about Webex Teams, there is hop for you - I cam across this problem just the  other day
Here is the new STUPID AND SEVERELY LIMITED user interface: (Normally much wider - I squashed it to take the screen dump without revealing the messages)
Now the tip is in the message - just go back to the OLD version! And voila!
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
