sharing slideshow with powerpoint
janeowens50
Community Member
I run training sessions for a client using their Webex platform. I join via the my Webex App and the host makes me host. I click on file and share to display my slides and then my powerpoint doesn't always load. I am shown an orange progress bar which stops at under halfway through loading and then I am kicked out and have to start again. Sometimes the slides load straight away but often I have to work from a colleague's slide show as mine won't load. . How can I overcome this? Any ideas welcome! Thank you in advance.
Clare Davis, Webex SME
Hi janeowens50!
This too has happened to me before when sharing my PowerPoint using Share > File.  This is how I fix it.
I use a PC, so I perform a Ctrl - Alt - Delete and to into my task manager.  Once the task manager opens locate anything (Under "Apps" or Background processes")  that says "Microsoft PowerPoint" and end the task.  That should do the trick!
Response Signature
Hi janeowens50!
Response Signature
This issue is caused because a bad bandwidth in the client/participant side. After reading in the Webex knowledge site, the recommendation is share desktop with PowerPoint, do not share file. Best Regards
Ing. Luis Eduardo Ochaeta Universidad Galileo
Director Postgrado IoT / FISICC Guatemala
Cisco Networking Academy 7ma avenida final zona 10
ITC/ASC/AC Main Contact calle Dr. Eduardo Suger
CyberOps-Wireless-VoIP*-DEVNET zona 10
CCNA - CCNP Enterprise Of. 418, Torre I
CompTia A+ Linux+ Network+ Guatemala, Guatemala
IoT Specialist/Python Instructor 01010
IBM Data Science Specialist Phone: +(502) 24238000
Universidad Galileo / ESEC http://netacad.galileo.edu
Phone: +(502) 24238010 facebook.com/cisconetacadguatemala
[email protected] @netacadgt
facebook.com/leochaeta
@leochaeta
