How to trace polling result from past dated session?
Najwa
How to trace polling result from past dated session? I did not save the individual result right after the poll end.
Stephanie Knoop
If you are using the traditional polling functions Within webex, there is no way to retrieve the information if you did not save it before ending the meeting. I recommend that you try using Slido for polling moving forward, as it is available for all webex subscribers.
https://www.slido.com/features-live-polling
Response Signature
