05-14-2020 11:42 AM
Is there a limit to the number of panelists you can have in an Event? I haven't found anything to indicate a limit, but wanted to get confirmation and don't have time (or resources) to test this.
For example, according to Designate a Panelist, "Any number of attendees can be panelists." So, If for some reason, I want an Event with 1000 panelists, I could. Not that I do, I understand that is crazy, but I want to verify there is not limit.
Thank you!
Sources of research I've looked at:
https://help.webex.com/en-us/nrtrfsv/Panelist-Options-in-Cisco-Webex-Events#id_89507
https://help.webex.com/en-us/nrtrfsv/Panelist-Options-in-Cisco-Webex-Events#ID_2313_00000c63
https://help.webex.com/ld-7srxjs-CiscoWebexEvents/Webex-Events
Solved! Go to Solution.
05-14-2020 01:24 PM
Sometimes you just might need 1000 Panelists!!
So you can have as many Panelists as your Webex site capacity. If your site capacity is 1000 - then you can have 50 Panelists and 950 attendees. or 800 Panelists for 200 attendees. Your Webex Admin should know your site capacity. You can contact them by going to your Webex site and clicking on Support. Calling Webex Support at 1-866-229-3239 is another option also.
05-14-2020 01:24 PM
05-14-2020 01:28 PM
05-26-2020 05:17 PM
On the top of what have been said...if joining via video device, max panelist is 200. Note that attendees cannot join EC via video device and only panelist can.
