06-30-2014 10:42 AM - edited 11-18-2020 03:07 AM
7.6MR3 (7.6.130.0) is now posted in CCO. Beta for this release is over, thanks!
For any new issue during this test, please write to wnbu-mrbeta@external.cisco.com, pre-existing problems would be directed through normal TAC support channels, the image is TAC supported until CCO release of final code
AS_5500* can be used for Wism2/2500/5500 controller types
AS_7500* can be used for 7500/8500
AS_CTVM can be used for vWLC
CSCup22590 | Multiple Vulnerabilities in IOS/IOSd OpenSSL - June 2014 |
CSCuo33271 | Jian crashed with DP watchdog on image 8.0.72.164 |
CSCum71927 | Corfu: Handle all NF timeouts during hal reset |
CSCui57980 | WLC crash at task name 'aaaQueueReader' w/ 7.3.103.8 |
CSCuo21355 | AP shows logs with 'Bad refcount in datagram_done' traceback |
CSCup14580 | PR: Saber crash with envMonitorStatus missed software watchdog |
CSCup75604 | BGL-Alpha: 5500/WISM2 crashed with task name "spamApTask1" |
CSCun26383 | Memory corruption crashes in cac_parent_timer by rrm neigh tbl overwrite |
CSCum26370 | Static TX power level changes to Max after AP reboot |
CSCuq36902 | Memory Leak with Internal webauth in a loop for longer period |
CSCuq16408 | WISM2 multiple crashes on 7.6MR3 - Bonjour_Msg_Task |
CSCuq18025 | High CPU 99% on webauth Redirect Task 7.6.122.9 |
CSCuo69145 | 2504- Display new Dashboard after user login |
CSCuo60383 | Ap3602 trying to contain its own RM3000AC module |
CSCuo44048 | 3602 AP crashes in proc IPAM Manager |
CSCup87612 | Memory corruption on OpenSSL, 7.6.122.7 |
CSCuq08015 | 7.6mr3-Beta - WLC crash : spamGetRadGroupName |
CSCul31732 | FlexConnect Vlan mode was changed to Disabled after power cycle |
CSCup55226 | apple client cannot authenticate on 1130 1240 running 7.6 code with FT |
CSCup42789 | AP3602 with RM3000AC module not able to pass traffic |
CSCup60494 | Gradual memory leak in 2048 byte chunks |
CSCup40557 | HIGH CPU (98%) on webauthRedirect |
CSCup44648 | PMIPv6 - Add sshpm Rules for PMIPv6 Control only when MAG enabled |
CSCuo69578 | AP1532E/I bridge throughput is very low on 802.11n |
CSCun15192 | Radio Reset: (SC2) sensord crash due to dot11 driver off-channel timeout |
CSCui90116 | AP sends FT-auth original and retry packet to WLC causing MIC mismatch |
CSCuo71809 | Clean Air: Stale Bluetooth Device Entries in down state in AP with WSSI |
CSCul42704 | WIPS-Rogue APs are mistaken as infrastructure devices |
CSCul16911 | CAPWAP causing APs to disassociate due to DTLS errors |
CSCuo74061 | AP 1600 intermittent low throughput (<1-2mpbs) |
CSCum66202 | FlexConnect: per-user ACL + WebAuth, success/logout page not displayed |
CSCuo97883 | 3700 AP 5ghz clients stop forwarding traffic under load with Tkip |
CSCuo84219 | Wi-Fi: AP1600 drops packets when a burst of A-MSDU data is received |
CSCul04090 | Reaper Reset: Task "SNMPTask" missed software watchdog |
CSCul38572 | CCKM roaming failing between a 7.0 WLC and a 7.4. |
CSCul98577 | Wired Guest can leak traffic out WLC Management Interface |
CSCum86401 | LAP in UNKNOWN_STATE on WLC |
CSCun22507 | transfer run-config lacks WLAN and L2ACL configuration information |
CSCun38541 | Conditional web redirect not working |
CSCun69089 | Vocera Badges Broadcast stops working randomly |
CSCuo23909 | Flexconnect Efficient Upgrade,702W MASTER AP showing as invalid AP model |
CSCuo63046 | WLC crashes on task spamApTask6 |
CSCul78198 | RAID Volume Status should show proper error codes instead of unknown. |
CSCun48405 | AP sent Deauth to wlan client after channel chage by RRM DCA |
CSCsz82878 | 4.2 Mesh controller crashing with Task Name: reaperWatcher |
CSCui16915 | Darya IRCM:Guest tunneling broken with Katana as GC and Talwar as MC |
CSCui37300 | mDNS: WLC uses 0.0.0.0 as source IP for query/resp when use native VLAN |
CSCui38822 | OC: GUI won't allow change of HA 2ndary controller to primary controller |
CSCui56456 | RNG in Web Management Cookie is not cryptographically secure |
CSCui94634 | Flex AP disjoins after ACL push, CAPWAP processing hangs DTLS timeout |
CSCui95938 | fast Switching SSDi and IPAD Issue |
CSCuj04921 | Xale: S4, Linksys 3x3 and Macbook Air clients not reach m8/m9 data rates |
CSCuj05274 | WLC Crash - Reaper Reset: Task "loggerMainTask" missed software watchdog |
CSCuj61455 | FlexConnect Clients are being Deauthenticated for an Unknown Reason |
CSCul03672 | commands of backup-controller are lost after restoration on 7.5.102.0 |
CSCul15555 | FlexConnect AP decrypt errors after CCKM roam, phone stuck in DHCP req |
CSCul91975 | WGB may disconnect permanently after max retry of 802.11 probe |
CSCum00101 | AP 2600/3600 data tunnel stuck w/ dtls encryption enable |
CSCum15629 | 1140 AP in Flexconnect Mode crash on 7.4.110.0 due to auth timer in loop |
CSCum53429 | AP1130 FlexConnect VLAN mapping corrupted after VLAN mapping change |
CSCum63497 | vWLC 7.6 Service port on distributed switch breaks communication |
CSCum67742 | Radius HTTP Profiling not working in latest pineridge build |
CSCum71699 | flex ap BVI down on vlan mapping push |
CSCum87504 | MFP Anomaly Detected messages continuously displayed |
CSCun11124 | vWLC serial number changes when using DRS or Vmotion |
CSCun23679 | WLC:protcol pack 6.3+ will not DP crash file |
CSCun34605 | Radius profiling failing for Windows XP and 7 |
CSCun52751 | AP802 as MAP not falling back from invalid static IP |
CSCun62368 | Radius NAC Client auth issues for 7.6 |
CSCun66868 | WLC crash at snmpApCurrChanChangedTrapSend |
CSCun85954 | 7.6 : 5508 HA crash with Task Name: rsyncmgrXferMain |
CSCuo18300 | WLC: DNS based ACL feature is case sensitive and shouldn't be |
CSCuo20803 | acl rule direction is changed from any to out during backup |
CSCuo35247 | LAP unable to setup DTLS with WLC if packets arrive out of order |
CSCuo37056 | Rogue client and adhoc rogue client containment failure in 7.6 |
CSCuo39416 | 1131/1242 not forwarding CWA redirects on 7.6 |
CSCuo62930 | unable to map ACL to wlan through GUI. |
CSCuo63103 | Client local switching to central mode load, aaa override, radius nac |
CSCuo68049 | Not able to set client RSSI shows positive value |
CSCuo71252 | Express Setup Wizard,Country and Timezone set to US regardless of config |
CSCuo73572 | Unable to add 8510/7510 Controller to Prime 2.1 |
CSCuo86478 | WLC Set Wrong DHCP Relay Agent for Layer-2 Roaming |
CSCuo86819 | WLC crashes in 7.6.120.0 - memory corruption caused by Webauth |
CSCup03264 | Anchor WLC not appending client parameters for external webauth redirect |
CSCup18354 | Japanese DBCS characters is garbled in internal Webauth login.html page |
CSCup22587 | Multiple Vulnerabilities in OpenSSL - June 2014 |
CSCuj10329 | FlexConnect AP crash in dot1q_vlan_exists() after IP addr change |
CSCuj62550 | Traceback observed when adding flex-ap to flex-group |
CSCup24962 | AP2700 crashed during scale MC2UC longevity |
CSCuo44310 | AP 3600 loses country code on reboot, joins Disabled |
CSCup59660 | SYS-3-CPUHOG related traceback in 3600 AP |
After code upgrade to 7.6.120 , two of our WLC's are crashing. Looks like CSCuo86819 is the cause for one of them.
I do not know for sure on second WLC.
Hesitant to go with beta even though it has a fix for CSCuo86819 because this bug was caused during one of the MR release!
When will this code be tested and be available to public?
hi
Thanks for your feedback.
CSCuo86819 is already fixed in 7.6MR3, and included in the beta
The release will be in CCO in the coming weeks.
regards
Can you tell me when this version might be released to CCO?
The CCO version for 7.6mr3 would be 7.6.130.0 and expected to be released by end of this Month.
Regards.Salil
I noticed that 8.0 code has been released. Is this the same as 7.6 MR3, or is this a different release?
That is a different code. v7.6 MR3 should be out by the end of the month or first week of September.
Scott
no, 7.6MR3 is a maintenance release, just bug fixes, 8.0 is a new feature release, separated branches/release schedule
7.6.130.0 will be posted soon
regards
