Core Issue
Configuring a base station.
Resolution
If you are running Microsoft Windows 95, 98, 2000, ME or XP, follow the instructions detailed in Configuring the BSE342 and BSM342 Base Stations using the Base Station Client Utility (BSCU).
If you are running Linux or Mac OS, use a web browser or telnet client to configure the base station using HTTP or telnet.
Problem Type
Configure / Configuration issues
Products
Base Station
