TCC_2
Level 10
Level 10
Introduction
How to disable SSID broadcasting in Cisco Access Point (AP)
Resolution
The concept of broadcast Service Set Identification (SSID) is referred to as Guest mode in IOS. The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more  secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with  the access point. It also allows clients configured without a SSID to associate to Access Point.
To disable SSID broadcasting in Cisco IOS Software
perform these steps:-
1.  Go to the SSID Manager page.
2.  There is a selection for Guest Mode which is probably checked. To stop SSID from being broadcasted, un-check the Guest Mode.
To disable SSID broadcasting in VxWorks
1.  Go to Setup --> AP Radio Hardware or HW Radio.
2.  Make sure Allow broadcast SSID to associate is not selected. If is it selected, uncheck the option.
The command to dissable the SSID broadcast from CLI is " no guest-mode"
under the interface ssid .Perform these steps to disable SSID broadcast:
1.  AP(config)#interface dot11Radio 0
2.  AP(config-if)#ssid
3.  AP(config-if-ssid)#no guest-mode
For more information on guest-mode (SSID configuration mode), refer to Cisco IOS Commands for Access Points and Bridges:-
For more information on wireless LAN security, refer to the Use of SSID section of Wireless LAN Security White Paper:-
Problem Type
Configure / Configuration issues
Products
Access point
Workgroup bridges
Security Options
SSID
Product OS
IOS
VxWorks
Related Documents
Disabling SSID Broadcast on a Linksys VOIP Router:-
FAQ on Cisco Aironet Wireless Security
Related Discussion on Cisco Support Community
Disable the SSID broadcast on a Cisco 1811W
Enabling SSID broadcast on Cisco 871W ISR
johnlloyd_13
Level 9
Level 9
hi,
just to add, you could disable SSID broadcast (on autonomous WAP) under ssid config mode:
AP(config)#dot11 ssid 3333
AP(config-ssid)#no mbssid guest-mode
AP(config-ssid)#do sh dot11 bssid
Interface      BSSID         Guest  SSID
Dot11Radio0   003a.9910.xxxx  Yes  1111
Dot11Radio0   003a.9910.yyyy  Yes  2222
Dot11Radio0   003a.9910.zzzz  No  3333
How about if i use Wireless controller?
johnlloyd_13
Level 9
Level 9
hi,
you can disable it under WLANs > click WLAN ID > General > uncheck "Broadcast SSID"
i used a WLC 2504 as an example. see attached pic.
Fadi Shaya
Community Member
Hello All,
I have 2500 WLC with 75 APs, I am using 3 SSID for our locations, Voice, Wifi and Guest each with different Vlan
I want to hide wifi SSID on 5 APs only which is related to my BO. is it possible !! thank you
Attached is the WLC version
Antropitecus
I believe so, you should group APs and then apply settings to this particular array...
