TCC_2
Level 10
Level 10
Core Issue
Users created in an AAA server are given the lowest level of access, Level 1, by default. With this privilege level, users can access read-only information pages from the Access Point (AP) user interface. Options that require read-write access pages prompt you for Level 15 access.
Resolution
In order to disable the Level 15 Username and Password prompt, configure the group or user settings on the Cisco Secure ACS for Windows server to grant Level 15 access the first time the user logs in.
In order to provide Level 15 access to users for admin authentication, issue the shell:priv-lvl=15 command under Cisco IOS /PIX Firewall RADIUS Attributes. You can configure Cisco IOS/PIX RADIUS Attributes under the Group Setup section for the user group on the AAA server.
Similarly we can use the same informaiton on Cisco IOS routers as well. Here is the Configuration Example :-
The with default keyword authorization will get applied on all the lines i.e.  CONSOLE,  VTY, AUX. In  case you want it for users who are trying to login to via ssh or telnet use the  following:
EXEC  AUTHORIZATION
Router
router(config)#aaa  authorization exec Cisco group radius local
router(config)#line vty 0  15
router(config-line)#authorization exec Cisco
On Cisco Secure ACS:-
Interface  configuration
Check  user & group for cisco  av-pair.
User  setup à cisco ios/pix 6.x radius attributes àcisco av-pair [  shell:priv-lvl=15]
OR
Group  setup à ios/pix 6.x radius attributes à shell:priv-lvl=15
In case of radius  if exec authorization is enabled  and if  have not specified any privilege level in the ACS server. Then user will fall  under the privilege level 1 and if enable authentication is enabled  or enable password is defined  on the router then we can go to enable mode  by typing en or en <priv-lvl>
For more information, refer to User Group Management.
User group management:-
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/g.html
Interface configuration:-
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/i.html
Problem Type
Configure / Configuration issues
Products
Access point
Security Options
ACS
Client OS Type
Windows
Product OS
IOS
