TCC_2
Level 10
Level 10
    Introduction
    How to install the ACU and enable LEAP or EAP
    Resolution
    For information on installing the Cisco Aironet Client Utility (ACU) to enable Light Extensible Authentication Protocol (LEAP) or Extensible Authentication Protocol (EAP) for Microsoft Windows 95, 98, NT, 2000, and Me, refer to Installing the Client Adapter.
    • Step 1 Make sure the client adapter is not inserted in your computer. You will be instructed when to insert it.
    • Step 2 Use your computer's web browser to access the following URL:
    http://www.cisco.com/cisco/software/navigator.html?mdfid=278875243
    • Step 3 Click Option #2: Aironet Wireless Software Display Tables.
    Note
    If you prefer to use an automated tool, you can download software from the Software Selector tool instead of the display tables. To do so, click Option #1: Aironet Wireless Software Selector, follow the instructions on the screen, and go to Step 7.
    • Step 4 Click Cisco Aironet Wireless LAN Client Adapters.
    • Step 5  Under Aironet Client Adapter Installation Wizard (For Windows), click 802.11a/b/g (CB21AG, PI21AG).
    • Step 6 Click the Install Wizard file with the greatest release number.
    • Step 7 Complete the encryption authorization form; then read and accept the terms and conditions of the Software License Agreement.
    • Step 8 Click the file again to download it.
    • Step 9 Save the file to your computer's hard drive.
    • Step 10 Use Windows Explorer to find the file.
    • Step 11 Double-click the file. The "Starting InstallShield Wizard" message appears followed by the Preparing Setup window (see Figure 3-1) and the Cisco Aironet Installation Program window (see Figure).
    • Step 12 Click Next. The Setup Type window appears
    Step 13 Choose one of the following options:
    Note
    To ensure compatibility among software components, Cisco recommends that you install the client utilities and driver.
    • Install Client Utilities and Driver (recommended)—Installs the client adapter driver and client utilities.
    • Install Driver Only—Installs only the client adapter driver. If you choose this option, click Next and go to Step 25.
    •Make Driver Installation Diskette(s)—Enables you to create driver installation diskettes that can be used to install drivers using the Windows Device Manager.
    Step 14 Click Next.
    Step 15 If a message appears indicating that you are required to restart your computer at the end of the installation process, click Yes.
    Note
    If you click No, you are asked to confirm your decision. If you proceed, the installation process terminates.
    The Choose Destination Location window appears.
    Step 16 Perform one of the following:
    •If you chose the first option in Step 13, click Next to install the client utility files in the C:\Program Files\Cisco Aironet directory.
    Note
    If you want to install the client utilities in a different directory, click Browse, choose a different directory, click OK, and click Next.
    •If you chose the Make Driver Installation Diskette(s) option in Step 13, insert a floppy disk into your computer and click Next to copy the driver to the diskette. Go to Step 25.
    Note
    If you want to copy the driver to a different drive or directory, click Browse, choose a new location, click OK, and click Next.
    Step 17The Select Program Folder window appears.
    Step 18 Click Next to add program icons to the Cisco Aironet program folder.
    Note
    If you want to specify a different program folder, choose a folder from the Existing Folders list or type a new folder name in the Program Folder field and click Next.
    Step 19 If your computer is running Windows 2000, go to Step 25. If your computer is running Windows XP, the IMPORTANT: Please Read! window appears.
    Step 20 Read the information displayed and click Next. The Choose Configuration Tool window appears
    Step 21 Choose one of the following options. Table 3-1 compares the Windows XP and ADU client adapter features.
    •Cisco Aironet Desktop Utility (ADU)—Enables you to configure your client adapter using ADU.
    •Microsoft Wireless Configuration Manager—Enables you to configure your client adapter using the Microsoft Wireless Configuration Manager in Windows XP.
    Step 22 Click Next.
    Step 23 If you chose Cisco Aironet Desktop Utility (ADU) in Step 21, go to Step 25. If you chose Microsoft Wireless Configuration Manager, the Enable Tray Icon window appears.
    Step 24 Check the Enable Cisco Aironet System Tray Utility (ASTU) check box if you want to be able to use ASTU even though you have chosen to configure your client adapter through Windows XP instead of ADU and click Next.
    Step 25When prompted to insert your client adapter, perform one of the following:
    •If you are using a PC-Cardbus card, insert the card into your computer's Cardbus slot; then click OK. If the Windows Found New Hardware Wizard appears, click Cancel.
    Note
    Refer to the "Inserting a PC-Cardbus Card" section for instructions on inserting a PC-Cardbus card into your computer.
    •If you are using a PCI card, click OK. You will insert the card into your computer after you have finished installing the Install Wizard.
    The Setup Status window appears.
    The installation process begins, and you are notified as each software component is installed.
    Step 26 When a message appears indicating that your computer needs to be rebooted, click OK and allow your computer to restart.
    Step 27 If you are using a PCI card, insert the card into your computer's PCI slot.
    Note
    Refer to the "Inserting a PCI Card" section for instructions on inserting a PCI card into your computer.
    Step 28 If the Windows Found New Hardware Wizard appears after your computer reboots, click Next, allow the wizard to install the software for the client adapter, and click Finish.
    Step 29 If your network setup does not include a DHCP server and you plan to use TCP/IP, follow these steps for your operating system.
    •Windows 2000
    • a. Double-click My Computer, Control Panel, and Network and Dial-up Connections.
    • b.Right-click Local Area Connection x (where x represents the number of the connection).
    • c. Click Properties.
    • d. In the Components Checked Are Used by This Connection field, click Internet Protocol (TCP/IP) and Properties.
    • e. Choose Use the following IP address and enter the IP address, subnet mask, and default gateway address of your computer (which can be obtained from your system administrator).
    • f. Click OK to close each open window.
    •Windows XP
    • a. Double-click My Computer, Control Panel, and Network Connections.
    • b. Right-click Wireless Network Connection x (where x represents the number of the connection).
    • d. In the This Connection Uses the Following Items field, click Internet Protocol (TCP/IP) and Properties.
    Step 30  If you are prompted to restart your computer, click Yes.
    Step 31 Now that your client adapter is properly installed, it is ready to be configured.
    •If you are planning to configure your client adapter through ADU, go to Chapter 4, to create configuration profiles.
    •If you are planning to configure your client adapter through the Windows XP Wireless Configuration Manager
    Special attention should be paid to the use of strong passwords. Cisco LEAP is a password-based algorithm. To minimize the possibility of a successful dictionary attack, use strong passwords, which are difficult to guess. Some characteristics of strong passwords include:
    • A minimum of ten characters
    • A mixture of uppercase and lowercase letters
    • At least one numeric character or one non-alphanumeric character (example: !#@$%)
    • No form of the user's name or user ID
    • A word that is not found in the dictionary (domestic or foreign)
    Problem Type
    Install
    Products
    WLAN adapters (wireless card) / ACU (Aironet Client Utility)
    Reference
