http://www.youtube.com/watch?v=eHOQe56QBpA
This video ended up being a lot longer than I thought it would. Below should be a config you can just paste in to a 3850 then reboot it and it should come up as a configured controller.
hostname 3850
boot-start-marker
boot-end-marker
########Username
username testing privilege 15 secret testing
no aaa new-model
switch 1 provision ws-c3850-24p
ip device tracking
######### DHCP for APs, no option 43 needed because they are on the same subnet as WLC######
ip dhcp pool APs
network 10.10.0.0 255.255.255.0
default-router 10.10.0.1
dns-server 10.10.0.1
######### DHCP for wireless clients, removed if you already have DHCP server######
ip dhcp pool Clients
network 10.50.0.0 255.255.255.0
default-router 10.50.0.1
dns-server 10.50.0.1
interface GigabitEthernet1/0/1
description CAPWAP AP
switchport access vlan 10
switchport mode access
interface Vlan1
no ip address
shutdown
interface Vlan10
description Management Interface
ip address 10.10.0.2 255.255.255.0
interface Vlan50
ip address 10.50.0.1 255.255.255.0
ip default-gateway 10.10.0.1
no ip http server
ip http authentication local
ip http secure-server
ip sla enable reaction-alerts
line con 0
logging synchronous
line vty 0 4
logging synchronous
login local
line vty 5 15
logging synchronous
login local
####### This set switch as an MC####
wireless mobility controller
####### This sets the interface the APs will talk to#####
wireless management interface Vlan10
####### Enables management over wifi########
wireless mgmt-via-wireless
####### WLAN config #######
wlan testing1234 1 testing1234
client vlan 50
no security wpa akm dot1x
security wpa akm psk set-key ascii 0 testing1234
no shutdown
end
