Vinay Sharma
Level 7
Level 7
Introduction
Unable to Import Auto Cad Files into Wireless Control System (WCS)
Scenario
When trying to import an Autocad file into WCS, getting the following error:
Unable to convert the auto-cad file. Reason: Error while loading the auto-cad image conversion library. (no Ax2008Dll in java.library.path). Please refer online or WCS documentation for more information.
Found  the following files are missing:
\webnms\rfdlls\LIBGFL254.DLL
\webnms\rfdlls\MFC71.DLL
\webnms\rfdlls\MSVCR71.DLL
\webnms\rfdlls\MSVCP71.DLL
The documentation says to rectify the issue:  If there are any dependency issues, fix them by installing the required libraries for missing dependencies and then restart WCS.
But, for the life of me, I cannot find an installer that will fix this.  I have the latest 7.0.172.0.
Solution
1.     Stop WCS Service.
2.     Under <WCS INSTALL DIR>/webnms/lib there should be 2 files as AxConverter.dll and AxConverter.lib2. Rename the files as
  • AxConverter.lib to Ax2008Dll.lib
  • AxConverter.dll to Ax2008Dll.dll
3.     Power cycle WCS server
Related Links
This document was generated from the following discussion: Unable to Import Auto Cad Files into WCS
Adding Floor Plans to a Campus Building
Adding and Using Maps
